Umik-1: Handleiding
Voor diegene die de Umik-1 gebruiken, hierbij een korte handleiding
UMIK-1 setup with REW</strong>
With the miniDSP UMIK-1, you have an easy way to get started with acoustic measurement: to optimize and equalize your subwoofer, to correct for room effects, or even to design your own loudspeakers! In this application note, we'll show you how to get up and running with the UMIK-1. 1. Get connected
Mount the UMIK-1 into the small stand supplied with it, or if you like, you can use any other microphone stand. Connect the UMIK-1 to your computer using the supplied USB cable. UMIK-1 connection
Connect an audio output from your computer to your sound system. With most computers, you can use the line out or headphone output with a suitable cable. It is advisable to connect into your system at the preamp inputs, so that the preamp volume control can be used to manage the signal level from the computer. Audio connection
2. Get your calibration file
Go to the UMIK-1 page and enter your microphone's serial number. It is in the form xxx-yyyy and labeled on the microphone. Use "Save As" in your browser to save the numbers as a file e.g. 7000343.txt.
The calibration file ensures that your microphone is as accurate as possible. Each microphone has a unique calibration file, which is why the serial number must be entered.
"Sens Factor =-16.273dB, SERNO: 7000343"
20.396 -0.376769317
22.242 0.434645133
24.255 0.819522375
26.4503 0.869646823
3. Set up Room EQ Wizard
Download Room EQ Wizard from Home Theater Shack. You should get the latest version from the download area as at least 5.01 beta 14 is needed to operate with the UMIK-1.
Once installed, start REW. You will see a screen asking if you want to use the UMIK-1. Click on Yes. (If you don't get this screen, go to the REW Preferences window and set the Sample Rate to 48 kHz.) UMIK-1 detected
Answer Yes to the next question about the calibration file, and then locate the file that you saved above. Use cal file?
4. Set levels
The UMIK is automatically calibrated by REW for sound level (this information is in the calibration file). You will want to set your system to generate a suitable signal level, though. Click on the Signal Generator button and set the parameters like this (the top frequency parameter, "24,000" in this example, isn't relevant, you can ignore it): REW Signal Generator
Position your microphone at the listening position and turn the volume of your system down. Then click on the Play button (green triangle), and turn the volume up until the test signal is at a comfortable level.
Now open the REW SPL Meter. Click on the red button in the lower right corner to turn it on, and adjust your system volume until the meter reads about 75 dB. REW SPL Meter
5. Run a measurement sweep
Click on the Measure button near the top left of the main REW Screen. Check that the level is set to -12 dB, and click on the Start Measuring button. Making a measurement
REW will make a "whoo-oop" sound through your speakers. A short time later, you should see your first in-room measurement! <strong>Example measurement
Note: if you're measuring primarily bass frequencies, it's better to run both speakers at the same time. If you're measuring full-range and looking at from, say, 200 Hz and up, it's better to run just one speaker - just disconnect one of the cables. Depending on the type of measurement, you may also want to apply some smoothing to it from REW's "Graph" menu.
rho
Active Member
13 aug 2013
1.133
39
Kan je ook gewoon de audio over hdmi naar je receiver sturen om metingen uit te voeren of gaat het enkel over de analoge uitgang van de pc? Ik zou REW namelijk op de htpc kunnen installeren en dan kan ik het bijna zoals Audyssey op de receiver gebruiken. Hoef ik enkel een UMIK-1 aan te sluiten en dan ben ik klaar.
rho
Active Member
13 aug 2013
1.133
39
Geweldig. Bedankt voor de link.
John Carlton
16 mei 2014
825
220
Gent
Heb even gezocht maar vind niet direct hoe ik aan een umik-1 geraak hier in België (muv bestellen via minidsp in de VS). Hoe\waar zijn jullie er aan geraakt?
4.116
De mijne komt Rumoh. Als ik het me goed herinner had ik hem de dag na m'n bestelling al.
John Carlton
16 mei 2014
825
220
Gent
Chr1st0f" data-link="http://home-theater.be/topic/504-Umik-1-Handleiding?postID=23287#post23287"> [url="http://www.juoiga.eu/index.php?p=2&amp;merk=2&amp;id=90 zei:
http://www.juoiga.eu/index.php?p=2&merk=2&id=90[/url] http://www.rumoh.eu/nl/meten/4236-umik-1-.html http://shop.speakerenco.nl/umik-1 </woltlab-quote>
dank u wel
<woltlab-quote data-author="broodro0ster"] De mijne komt Rumoh. Als ik het me goed herinner had ik hem de dag na m'n bestelling al.
Die van Rumoh had ik wel al gezien maar daar staat geen prijs bij en ook niet direct voor 'm in het winkelkarretje te leggen. Ik veronderstel dat degene die em gebruiken even blij zijn als de gemiddelde review en dat het toestel bijgevolg zijn aankoop rechtvaardigd?
4.116
Ik heb 90euro excl. shipping betaald. Ik vermoed dat hij niet meer op voorraad is als je niet direct kan bestellen.
Philip
18 nov 2014
1.053
90
80
@John Carlton, ben je nog op zoek naar de UMIK-1? De mijne komt van HomeStudio, €90 inclus (snelle) verzending.
John Carlton
16 mei 2014
825
220
Gent
duboisph zei:
John Carlton</woltlab-metacode>, ben je nog op zoek naar de UMIK-1? De mijne komt van HomeStudio, €90 inclus (snelle) verzending.
Jup! Bedankt voor de tip. Ik heb ergens nen site gevonden in Duitsland voor 80 € maar weet niet of dat incl. verzending is. Kga het zeker bekijken thx.
davylermi
5 okt 2014
219
21
Heb er mij zonet ook eentje besteld, lijkt mij veel eenvoudiger om mee te werken dan met mijn huidige Behringer ECM8000/Externe geluidskaart-combo.
djaxx
2.237
33
Heb er eentje op het oog die ik voor 75 euro kan afhalen. Is die prijs wat aanvaardbaar voor een tweedehands umik-1 of aan de hoge kant. Perfecte staat volgens verkoper.
4.116
Een nieuwe kost 90euro zonder shipping. Ik geloof dat ik voor de mijne iets van een 100euro betaald heb incl. shipping bij Rumoh.
Ik zou zeggen dat het de moeite is als je er niet ver voor moet rijden.
2.151
Heb hier eens aan het meten geweest met die umik-1 maar kreeg het level niet echt goed . Als ik de levels in het groen kreeg zat ik tegen de 100 Db volgens mijne Db meter. heb nu gezien dat je voor hdmi die drivers moet gebruiken.....ga ze eens installeren en nog eens meten.
het meten zelf ging wel maar kon niet lager gaan dan 85 DB op de schaal van REW zelf.
4.116
En uwen calibratie heb je gedownload en geladen in REW?
